Replace Moonsoon HU
Old Apr 25, 2021 | 09:02 PM
Stage's Avatar
Default Replace Moonsoon HU
Hi there, looking to replace the factory Head Unit with a double din unit but keep the existing speakers and amp. Thoughts, recommendations? Thanks.
Old Apr 26, 2021 | 12:39 AM
VIP1's Avatar
Copy & Paste Moderator
This has been done many times and there are many threads.
Depends on which car, but if you mean a 1993-2002 Firebird.....
Pick the headunit you want, get the Metra Mounting Kit, get the Metra Wire Harness, do a little trimming if needed (to the opening or tray in the car were the stock radio sat), done.
1998-2002 Camaro is similar. 1993-1997 Camaro needs more work to fit.
If you have a steering wheel with buttons for radio, you'll need adapter for that as well.
If you have the BOSE setup, you need another adapter.
If you search this forum, you'll find install threads with pictures and part numbers for all the above.
