Sporadic Trip odometer resets to 0 issue
It makes much more sense to be the '99, this is a known issue with these. I didn't own my '99 long enough to encounter this problem, so I'm not sure if there is a fix besides just replacing the cluster. But it's definitely a documented problem if you try a search for issues relating specifically to the '99/1999 cluster.
and never had a problem but this issue is definitely an interruption in power to the gauges.When this happens, I would watch the voltmeter on the gauges. If it doesn't twitch, that would make me less confident in the gauge cluster, itself. (I would expect a power interruption from the battery, alternator, loose engine bay wire, etc. would also show with a flicker in the voltmeter gauge.)
If this is a problem in the cluster, I would bet its probably related to a cold solder joint issue - just like we see on many other components of the car. If one can find the spot where the issues is, the fix is pretty simple.
