Which ECU wire harness kit should I get?
The benefit of a used F-Body ECU wire harness is that all of the connections are already there, and the length is correct.
The benefit of a new one is that it is brand new and I can have it made with the LS7 injector connectors, but I would have to add pins/wires for any sensors not included, and I might end up having to coil up some excess wire length.
Inputs?
Now having said that I WOULD go ahead and rewrap it with some threaded wrap instead of factory electrical tape. I would find all the wires that look crappy and resolder some new ones if needed. You are wasting money buying a new one tbh.
- The car has had some electrical oddities lately, mainly pertaining to the IAC valve.
- The current harness is in a 1999 TA that has been in the AZ heat for all 22 of its years. This tends to make wires brittle.
- I will already have the engine/trans out of the car, so this would be the best time to replace the entire wire harness.
- I will only purchase a used harness if the vendor has inspected it and replaced anything that needs to be replaced. I will not buy an as-is used harness.
Basically, I am already going to be in there, so this would be the time to do it.
I am leaning rather heavily toward the Wiring Specialities harness. The come with high temp wrap and can have LS7 injector and MAF connectors so I do not have to have adapters.
I'm telling you man you would save a lot of money and effort just rebuilding the harness you have and doing it yourself. If you wanna burn some money then be my guest but I'm going to try and steer you away from that lol
