Proper wire size for powering Amp
Old Jul 17, 2021 | 12:05 PM
Double Aught's Avatar
Default Proper wire size for powering Amp
I have mounted a 350 watt amp near the Monsoon amp in the back to power my subwoofer. I read where for the distance from power source a 4awg wire is required. Do I really need to run that thick of a power lead?
Old Jul 17, 2021 | 12:55 PM
WhiteBird00's Avatar
Ungrounded Moderator
Depending on what class of amp you have (class AB or class D) you could go with 8-gauge (class D amp running 350 watts RMS with a cable length of up to about 20 feet) or 6-gauge (class AB amp in the same situation). 4-gauge is more common than 6-gauge so that might be the better choice. Also, 4-gauge will give you some headroom should you decide to upgrade later. Don't forget that the ground wire should match.
Old Jul 17, 2021 | 01:41 PM
Thank you for the reply. If I had bothered to read the specs of the amp, Sound Ordnance M350-1, Crutchfield recommends 8g.Sometimes I amaze myself. I won't be upgrading later, so I think the 8g will suffice. I'm going to route it off the hot lead at the underhood fuse box location. I did read where its a good idea to seperate amp power lead from signal leads.
