Lights not working right!!!!!!
I'll give you an example. I repaired several S10's with the issue that the brake lights work until you turn on the headlights, Then the brake lights quit and the tail lights are dim. The fix is to replace the ground wire connector at the rear where it connects to the frame, That's just an example for an S10 so it may not apply to your car.
