Sub Crossover Wiring with Stock Stereo
Old Mar 16, 2022 | 02:45 PM
H8Rain's Avatar
Default Sub Crossover Wiring with Stock Stereo
I'm hooking up a single 10" sub and amp. My head-unit is stock, so no RCA jacks to get the signal to the amp. So I ordered a LCI2 converter. The plan is to tap into the rear speakers for a signal. My questions therefore are.....
1. I'm told the speaker wires in tap into need to be FULL RANGE. Are either of the speakers in the rear hatch full range (the tweeter or mid wires)?
2. Since I am hooking up only (1) sub do I only need to pull a signal from one speaker or should I still pull a signal from both the left and right speaker?
Thank so much!
Old Mar 17, 2022 | 07:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
1. The 4" speaker in the hatch area receives full range signal from the Monsoon amp in both Camaros and Firebirds. The hatch tweeter (Firebirds only) receives full range signal directly from the head unit but there is an inline passive high pass filter before the speaker so you'd have to ensure you picked up signal before that. Personally, I would pull signal from the sail panel sub because it is already low pass filtered.
2. One side (closest) is quite sufficient.
Old Mar 17, 2022 | 07:59 AM
H8Rain's Avatar
That's what I thought. Thanks for confirming!
