2000 Firebird Hazard Lights Not Working
I have the stock flasher untis in both turn signal and flasher signal and have swapped with same result so both flashers work for the turn signals.
Going through the steps:
Step 3 - I probe C216 terminal K with a test lamp and turn the switch on - the lamp does not flash but has a steady light
Step 5 - Test lamp on flasher terminal B - no flash
Step 7 - Test lamp to flasher terminal A - lamp illuminates
Above steps seem to point to replacing lamp flasher but the flasher works on the turn signal and it is the stock part. Anyone else run into something like this?
Your test of the flasher is producing the expected results for a factory flasher. Testing with a test light at the terminals (with the flasher plugged in) will produce steady illumination on both sides - terminal A because it is the power input from the STOP/HAZARD fuse and terminal B because the test light doesn't provide enough load to make the thermo-mechanical flasher flash.
Unfortunately, that is where I was thinking this journey would lead. I do have a multimeter so can do those tests this weekend when I am playing with the cluster in the other thread.
A local auto electric wanted $100 to diagnose so I bought the factory service manual instead. I am not a fan of going into steering columns but will look for an opportunity to do so and replace the switch after I run the tests you suggest.
Thanks again!
