Brake Lights causing Check Gages
Old Jan 2, 2023 | 12:53 PM
White94Bird's Avatar
Default Brake Lights causing Check Gages
I noticed today when I press the brakes my check gages light will sometime flash for a split second and my battery gauge will dip for a sec and immediately recover. If my headlights are on its more noticeable. Do you think it could be a worn brake light socket?
Old Jan 16, 2023 | 07:49 AM
If anyone reads this, I found the abs sensor wire on the passenger side was resting on the header and shorting out when applying the brakes.
