Door lock actuator
Old Jan 12, 2023 | 01:15 PM
blackbirdls1's Avatar
Default Door lock actuator
I replaced the driver side door actuator and followed the thread/ video that is floating around out there. However, now I have an issue. Not sure if it's being caused by the replaced part or something else. The accessories retain power after my key is removed and engine off. I cannot use the door lock switch to unlock, only works when key is in. If i open the passenger door, I can utilize the lock switches both ways and the security red dash pad light is on or blinks like normal. However, when the doors are closed this turns off. Something is off and acting weird. Any suggestions on where to start? I want to assume it has to something to with the part I replaced. The reinstall went smooth.
