DRL’s / Auto Headlights Not Working
Old Apr 4, 2023 | 02:02 AM
CorbinEvans14's Avatar
Default DRL’s / Auto Headlights Not Working
Bought a 2002 Camaro awhile back and since I’ve owned it there’s been this constant issue where the DRL’s will click on and off randomly. You can actually hear the relay under the dash going crazy. Also, my automatic headlights never work. Always have to use the switch. I tried replacing the relay at one point and it fixed the problem for about 20 minutes before going back to no DRL’s. Turn signals work fine. I figure maybe there’s a short somewhere or the DRL module itself is shorting. Any help would be great.
Old Apr 5, 2023 | 09:56 AM
WhiteBird00's Avatar
Ungrounded Moderator
Well, since there is no headlight relay other than the one inside the DRL module, I would say that your DRL module is faulty. I don't know what relay you replaced but it certainly wasn't a headlight relay. The DRL module has internal relays for each of the front lamps which switch them between DRL mode and turn signal mode; and parking light and headlight relays which control the automated operation of those lights. So a bad DRL module would be a single point of failure that fits all of your symptoms. Those relays are considered non-serviceable parts by General Motors although I suppose they could be replaced if you're good at soldering. Otherwise, replacing the module is the easiest way to fix the problem.
Old May 12, 2023 | 05:13 AM
Well I ended up buying a used module on eBay to replace mine with. Everything works great now!
