02 sensor problem with air fuel gauge
Old Apr 11, 2023 | 09:19 PM
Heethen's Avatar
Default 02 sensor problem with air fuel gauge
2001 camaro ss, I am installing auto meter air fuel gauge 6175 because I bought it years ago and it was all but hooked up to the o2 sensor, I ran a wire from the sensor to the gauge and it doesn’t work but if put my meter in between the o2 and gauge it works fine and reads between .48 and .62 depending on throttle position. I also have a Diablo hand held in case that helps for readings or codes.. if I go from o2 to ground it reads around .050 what am I missing hope this is the right thread..
