Component speakers - 2 Ohms or 4 Ohm?
Old Apr 28, 2023 | 01:29 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Component speakers - 2 Ohms or 4 Ohm?
The amp that I am getting for my component speakers puts out the same power 2 Ohm or 4 Ohm, and the component speakers can be wires in 2 Ohm or 4 Ohm. So, is there a sound quality difference between the two, or are these 2/4 Ohm devices just for wider range is uses?
Old Apr 28, 2023 | 07:12 PM
FCar2000TA's Avatar
Veteran: Air Force
I have read some stuff saying that 2 Ohm is louder but 4 Ohm is cleaner. Is that true?
Old Apr 29, 2023 | 11:10 AM
WhiteBird00's Avatar
Ungrounded Moderator
Yes,it is true that higher impedance is better for eliminating electrical noise in the wiring, which is why home systems tend to use 8-ohm setups, but in an already noisy environment like a car, you would be hard pressed to notice any difference. However, if you have no other reason to chose one over the other, a 4-ohm setup will usually run an amp a little cooler and will help eliminate any electrical interference even if it is essentially inaudible.
Old Apr 29, 2023 | 08:24 PM
FCar2000TA's Avatar
Veteran: Air Force
The amp is a Rockford Fosgate T400X4AD. Fan cooled, 100w RMS both 2 Ohm and 4 Ohm. Speakers are CDT 6.75 components that can be wired 2 Ohm or 4 Ohm.
Would you go 2 Ohm or 4 Ohm?
Old May 1, 2023 | 02:17 PM
If you want the best sound quality despite being in a noisy environment then 4-ohms is the way to go. It is very unusual to have an amp which producers the same RMS output into two different impedances - usually output into the lower impedance will produce more power.
Old May 1, 2023 | 02:48 PM
FCar2000TA's Avatar
Veteran: Air Force
The Alpine KTP-445Us in my TA are the same. 45x4 regardless of 2Ohm or 4Ohm.
