93 TA hatch speaker rec?
Old May 26, 2023 | 01:35 PM
F14D's Avatar
Default 93 TA hatch speaker rec?
I got the 10 speaker system with a Pioneer deck. The rear hatch speakers started popping and fuzzin, sounds sweet. I have bazookas in the sails and will have Kickers up front. Ebay is my usual go to. Reccomendations? Thanks
Old May 27, 2023 | 11:24 AM
wannafbody's Avatar
I think they are 4 inch, at least 98-02 are. Any will work.
Old May 30, 2023 | 09:40 AM
WhiteBird00's Avatar
Ungrounded Moderator
wannafbody is correct - they are the same as the later model Monsoon systems, but that means both a 4" mid and .75" tweeter on each side. Those hatch speakers are intended just for rear fill, so power and quality are not the primary concern. The tweeters are less likely to have blown than the mids, so a cheap pair of 4" full range speakers from Walmart or online would be the first thing to try.
Old Jun 19, 2023 | 01:26 PM
F14D's Avatar
Yeah I can hear the rears popping and fuzzing. Same question as last ime you helped, 4ohm or 2ohm, will it matter?
Old Jun 23, 2023 | 02:51 PM
For the hatch... 4 ohm.
Old Jun 25, 2023 | 02:43 PM
F14D's Avatar
Found some cheap Scosche 4s at Walmart. Ended up adding some Pioneer 6.5s because one of the kickers shat the bed. Oddly enough the car now has 14 speakers. Sounds decent enough. Got to cruise around and play with the EQ now but I'm a happy camper.
