99-02 Firebird Fuel Sensor Technical Question
I have an 85 TransAM with the 99-02 Firebird Fuel Sensor and fuel tank which usually runs off of a 5volt power supply from the PCM/BCM and has the ohms reading sent back into the PCM at Red#54.
Is it possible to instead power the sender at 12v for an aftermarket gauge and still get the same ohms readings, or will this just not work?
Works well because I can power the Arduino on the same 5v reference as well and not need to worry about upconverting the resistances from 5v to 12v or finding a compatible gauge.
https://www.thirdgen.org/forums/ltx-...e-4th-gen.html
