Alternator Replacement
Old Nov 17, 2023 | 06:29 PM
White94Bird's Avatar
Default Alternator Replacement
I know the old trick is a certain truck alternator but those are now old and high miles? What is everyone doing now?
Old Nov 17, 2023 | 07:20 PM
sjsingle1's Avatar
it still works great....have you tried it ?
Old Nov 19, 2023 | 10:23 AM
I'm hesitant to install an alternator with 75k to 100k miles or more that's all I can find.
Old Nov 19, 2023 | 08:44 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Powermaster makes an excellent stock replacement.
Old Nov 24, 2023 | 07:11 AM
What model am I looking for?
Old Nov 24, 2023 | 01:28 PM
Full Power's Avatar
4 pin regulator, 145 amp # 8292
stock pulley, they normally push 120 amps at idle speed.
I like to upsize alternator pulley to 68 mm diameter, slows the rotor down a bit.
Still good for 100 amps at low idle.
If weight is paramount, and you are not running rear heat, seat heat, snow plow, etc. the # 8247 is rated 105 amps has same 4 pin regulator, same mount pattern and works just fine.
Old Nov 24, 2023 | 04:55 PM
RPM WS6's Avatar
Looks like the current Powermaster replacement part number is 48242 (165amp). Many years ago, I remember them listing the 48206 as a stock replacement for this application, I think it still fits but doesn't have the air duct on the back. I don't think the 48242 was even offered at that time.
