Passenger side headlights not working.
Do you have a test light or multimeter? The next step is to check for power and ground at the bulb socket. There are three wires at the connector... yellow = low beam power, light green = high beam power, and black = ground. There is no fuse for the headlights - they're protected by a fusible link under the hood and both sides are on the same fusible link, so that is not the problem. In fact, both sides use the same power circuit up to a splice in the harness under the hood, so finding a break in the wire would be the next check if all else fails. However, I doubt that it's a broken wire - if it's not a bulb then it's far more likely to be the connector... rusted, corroded, or worn out so that it's not making a solid connection (i.e. loose terminals). I would say that it might be the ground for that side (a screw on the top side of the radiator support) except that the same ground is used for your DRL/turn signal/parking lights and you didn't mention them not working.
