Under mirror mount and hardwire radar detector
For the Trans Am, can I tap into the wires that go to the lights under the rear view mirror, or should I run a wire down to the dash and pick up a power source there? I'm not sure how much current the mirror light wires can handle, but if I switch them to LED would that help? Here are the two mounts I'm currently looking at, same mount just different wiring included...
https://www.amazon.com/Radar-Mount-Mirror-Bracket-3001109/dp/B0788XRBTV/
https://www.amazon.com/Radar-Mount-Mirror-Bracket-3001209/dp/B0788W1NC6/
Thanks for any help!
Some detectors have an option to recognize the change in voltage between the car being off or running and can use that to turn the detector on and off, but I don't know if the A1 has that capability.
