Radio Code Loc
Old Mar 24, 2024 | 08:20 PM
SS.Tom's Avatar
Default Radio Code Loc
My radio is in “Loc”. I have tried calling the hotline number idk if I’m using the wrong dealer number but every time I called twice I get a different 4 digit code the second time and neither of them worked. One started with 00 and the other 56 which you can’t even get those first two numbers on my car.
When I press the 2 and 3 button the number that come up are 082 then am fm button changes it to 084. I have a code written in my owners manual 1421 but that code isn’t working. And I get to “Inop” after a while of trying different codes. Also is there a way to get rid of the “inop” without letting the key sit in the run position for an hour. I did it once and it got rid of it but I’m worried about my battery dying.
If anyone could get the 4 digit code from my 082 084 number it would help greatly.
Old Mar 25, 2024 | 02:30 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Someone else was recently able to get one of these radios unlocked for a 2002 Trans Am. Check out post #8 of this thread for the info he provided:
https://ls1tech.com/forums/wiring-st...l#post20545752
Old Mar 25, 2024 | 02:28 PM
SS.Tom's Avatar
Thank You. The code from the 106010 service dealer number on the ac delco hotline worked. It was the 00 code that I tried earlier but it did work this time. So for anyone with 082 084 the code was 0061
