Lighting Issue 99 Camaro
The light switch works just fine. When the car is off I can switch between the parking lights and the headlights and everything works as it should. Once the car is on the light switch does nothing to turn this off.
This is really driving me nuts. I was reading that it could be the ambient light sensor that may be faulty or covered. I have yet to find it’s location but This car did come a dash overlay that’s covering the original damaged one.
Any help or suggestions are welcomed. Thanks
The light sensor is in the middle of the dash near the defroster vent. I suspect that the dash cover is covering it making it “think“ it's dark all the time. The solution to keep the automatic headlights feature working is to cut a small hole in the cover so that light can get through. Alternatively, you can disable the automatic headlights by getting under the dash, unplugging the sensor, and using a small piece of wire to short together the two sensor wires... zero resistance across those wires is read as bright light so the headlights will never turn on automatically (they will still work via the switch as normal). Be very careful when lifting the dash pad to get at the sensor as it gets very brittle over the years and can break fairly easily leaving VERY sharp edges (he says as he types with only nine fingers
