Dome Light Stays ON
Old Aug 18, 2024 | 02:36 AM
Magonsterz's Avatar
Default Dome Light Stays ON
Foot well lighting hack!
The other day reinstalled passenger side kick panel, had already pulled bulb for convenience but then noticed my dome light stayed on, turns out the bulb single filament bulb wire was grounding out. Wasn't the first time this had happen so finally decided to swap out antiquated set up for dual wire L.E.D. Well as luck would have it found a bulb with rubber grommet that is the exact fit for the stock bulb mount under dash which doubles as ground since wire is constant hot. Added benefit was no longer a holt bulb burning my self when digging under dash. Here is the ones I used, amazon has them for 8.99., just ground one to the bracket and bullet connectors for the hot and done."10PCS Sealed Waterproof White 3/4" Mini Round Clearance LED Front Rear Side Indicator Bullet Grommet Marker Bumper Grille Light for Truck RV Car Bus Trailer Pickup Van Caravan Boat"
Old Aug 18, 2024 | 02:55 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Originally Posted by Magonsterz
...exact fit for the stock bulb mount under dash...
Stock bulb under the dash? What vehicle are you referring to here?
Old Aug 18, 2024 | 11:16 AM
Magonsterz's Avatar
Gen 1 Camaro 67-69 but also found in 59-79 GM Vehicles
Old Aug 18, 2024 | 01:39 PM
Treburkulosis's Avatar
First gens were bad about that. I had to replace the one in my 67.
