Help me diagnose this issue...
I have no idea what's happening. Please help.
I attached some videos to show you. there google drive so i hope it helps
https://drive.google.com/file/d/1EpH...ew?usp=sharing
https://drive.google.com/file/d/1cXz...ew?usp=sharing
https://drive.google.com/file/d/1osJ...ew?usp=sharing
Judging by the way your right side turn indicator stays solid with headlights on, I suspect you'll find that one of the bulbs on the right side does not flash as it should. That will be the source of your problem - bright filament of that bulb burned out, socket not making good contact, problem with the wiring on that side, or possibly even a DRL module problem. There are ways to narrow it down once you've located the issue.
