Wiring in turn signal indicators
Old Jul 31, 2025 | 04:25 PM
Codys89RS's Avatar
Default Wiring in turn signal indicators
Afternoon!
After putting in the Holley screen with a aftermarket bezel I found I am missing my turn signal indicators and want them back.
The turn signals dont always click off when the wheel turns. Assuming something wrong with the cam.
Is there an easy way I could wire in a few lights and put them into the bezel?
I have two small led lights that would work great
Thanks in advance!
Cody
Old Aug 1, 2025 | 08:55 AM
WhiteBird00's Avatar
Ungrounded Moderator
You can tap into the light blue/white (left) and dark blue/white (right) wires at the base of the steering column or at the DRL module behind the radio to provide the flashing power to run indicator lights.
Old Aug 1, 2025 | 01:07 PM
Codys89RS's Avatar
White bird you are the best!
I was hoping it would be as easy as splicing into the wires at the base of the column!
