VATS System issue remembering key
The second problem is that there is no 667 ohm resistance used by GM. So, as wannafbody suspected, you have the wrong resistance. Here is a chart of the fifteen possible resistance values used for VATS along with the resistor or combination of resistors which will make up those values...
You used to be able to run over to Radio Shack and pick up the resistors really cheap, but these days you'll generally have to order them online. Measure your key again (or measure the spare key if you have it). Make sure the contacts are clean using rubbing alcohol to get a better reading. BTW, if your 667 turns out to really be 681, you can use a single 680 resistor instead of the 680 + 1 that I have in the chart - it will be close enough to work properly. I really need to update that chart.
