Steering wheel controls
Old Sep 3, 2004 | 09:08 AM
ws6-speed's Avatar
Another thing to consider would be placing the switch on your shifter. Then it could easily be hidden and would be right at your fingertips when you need it.
Russell
Old Sep 3, 2004 | 08:01 PM
adragster7104's Avatar
Right on, thanks guys for all your help.
The only reason I wanted to try and stay away from the PAC was to keep from having something else under my dash. I already have a lot of components from a data logger (racepak)
Thanks again for all your help
Old Sep 3, 2004 | 08:03 PM
I thought about the shifter button as well, but I wanted to do something different.
Old Sep 3, 2004 | 09:52 PM
EatRice's Avatar
Couldn't the steering wheel be taken apart and a single switch isolated? That is what I would do. Isolate one switch to control the blue wire. Then you can hook the blue wire to a relay. I would send ground through the switch which should be available in the steering wheel.
Old Sep 4, 2004 | 05:24 PM
samz28's Avatar
a small pic/atmel chip with a/d could easily decode the signal then output i/o (on/off +5v) to relay sets. This is EE101 kinda stuff. Someone should be able to program it, then you could maybe multiplex two buttons at once to do more tasks.
Old Sep 6, 2004 | 09:53 AM
ws6-speed's Avatar
kinda makes me wish I had taken EE101
