my amp is doing weird noises! help please!
anyway, after MUCH trial and error, i've replaced everything, rewired everything, and nothing solved the problem. as far as "what the hell is the problem?" goes, i really am not totally sure. i can tell you this: the buzzing noise is also coming from my driver's side mid-bass speaker (right behind the driver's seat). the noises are identical. i can plug/unplug the rca's and the mid-bass speaker still makes the same buzz. it's very odd.
the line-level output converter is about 4" past the connector that goes into the head unit. i had to obviously use splice connectors to get the converter connected. i am assuming, since i know everything is in working order and is wired correctly, the problem lies within the pin connection in the HU connector. i've even tried switching out the head unit. does anyone have any idea? or an idea as to how to fix this?
thanks for any help. i'm stumped. been dealing with this problem for several months, and i can't seem to beat it.
