Guage cluster lights not working.....
thanks
Wesley
thanks
Wesley
Any ideas what could be causing this? Same thing with it possibly being the headlight control/dimmer module itself?
Kinda need the dash lights to drive home from work tomorrow
once I took the old one out. the contacts are on a piece of what looks to be ceramic or a plastic type material. well once I took the old one out I noticed a piece of the white ceramic like substance. well upon inspection of the dimmer switch I took it apart and that ceramic type disc was in pieces. and the electrodes were not in the proper place b/c the cracks and the movement of the piece in the switch itself from me moving it. so now all is well. try that if all else fails.
hope that helps
Wesley
