remote wire splicing
Old Oct 13, 2004 | 04:24 PM
tuffluck's Avatar
Default remote wire splicing
can i just splice an additional wire off of my main remote wire to use for a 2nd amp? or do i need to run a completely new remote wire to that amp? thanks!
Old Oct 13, 2004 | 09:26 PM
LS1ruben's Avatar
Evan, i have had mine spliced for four years without any problems.
Old Oct 14, 2004 | 12:19 AM
chris99gmc's Avatar
splice away
Old Oct 14, 2004 | 12:31 AM
tuffluck's Avatar
cool, thanks
i'm also splitting my 4 gauge power wire to two different 8 guage wires, to run to both amps. i have the correct terminals for that though, but i don't think they are at enough power to need more than 8 gauge each.
Old Oct 14, 2004 | 06:34 AM
TA TED's Avatar
STF Veteran
Originally Posted by tuffluck
cool, thanks
You'll be fine. As long as you're not running two huge class "d" amps bridged. Just make good connections.
Old Oct 14, 2004 | 07:51 PM
Gregg 00SS's Avatar
You should be fine, I just installed my system and everything is working fine, well, atleast the power issues are ok. I ran 1 remote on wire to back, and then split it. Did the same for the amp power. 4 guage to the back into a distribution block, and then 6 guage to the amps.
