VIPER 790XV Valet switch problem
I installed my 790XV viper - it worked great but the Valet switch did not work. First, The car is a 2002 Camaro SS M6, so I decided not add the relays for starting the vehicle - just using the alarm. Does anybody have any ideas why the Valet switch does not work? The brain could be bad but maybe something has to hooked up that I did not connect because I wasn't use it. I would appreciate the help.
Thanks
Bill
PS: I buzzed the Valet switch and it worked. Also one side had 12V and when I push the button the gray wire had 12V.
PS2: Direct Electronics will not help unless you are dealer, etc.
