couple of amp questions
Old Nov 9, 2004 | 08:38 AM
kjac081's Avatar
Post couple of amp questions
First, does anyone have experience with Audiobahn amps? They look cool, and are not that expensive. Im looking at one of the cheaper ones to push a single 10.
Second, anyone know what wires to tap off of on the back of the factory radio for a line-out convertor? I see alot of people using the sub wires either at teh speaker or just after the amp, but I have been told that it is best to use a non-amplified source for the input because amps are made to operate with a low input voltage, and the amplified signal can cause damage. Thanks for any help. Kev
Old Nov 9, 2004 | 08:45 AM
kjac081's Avatar
nvermind on the amp, I just realized that their low end stuff is not 2 ohm stable. in only driving a IDQ 10 dual 4 ohm, wired for 20 ohm. 200-300 watts should be plenty. any suggestions?
