will this amp work?
Old Nov 16, 2004 | 07:00 PM
brandon1221's Avatar
Default will this amp work?
I am planning on gettin a stealth box with a JL audio 10w3 V2 sub, i was wondering if this amp would be a good amp to go with it:
phoenix gold zx350, specs are:
110x2 into 4 ohms
175x2 into 2 ohms
350x1 bridged into 4 ohms
Old Nov 17, 2004 | 08:45 PM
anyone have any input on it?
Old Nov 17, 2004 | 09:12 PM
tuffluck's Avatar
i think the jl sub you have is a 2 ohm sub, so if you are going with that amp, you'd either need two of those subs, or you'd need one SVC sub at 4 ohms instead.
Old Nov 17, 2004 | 11:01 PM
01WS6/tamu's Avatar
Do not hold me to it but I think the Phoenix amp is mono two ohm stable. If your sub is a two ohm DVC you can series parallel the two coils to get 4 ohms mono. Or run the amp in two ohm stereo with one coil on each output.
Old Nov 18, 2004 | 01:08 PM
the 10w3 is a dual voice coil and each coil has 2ohm. Which would make it 4ohm right? So would this figure apply to that: 350x1 bridged into 4 ohms, or is it not bridged if there are 2 2ohm voice coils?
