rear interior lights and trunk light out
also, i noticed when the trunk light is touching a metallic object, all the lights then turn on but wont turn back off.
any suggestions?
im stumped!!
i guess you have checked all your fuses? if so then try and trace the wires
the dome light wire that should show (-) when the door is open is white and it goes to the bcm
Does the radio turn off when you open the door?
If you said no to either of these, try the passenger door.
Its possible that there is a problem with the switch in the driver's side door lock mechanism.
