Need help installing aftermarket HU...
I'm installing a Kenwood DDX7015 6.5" touchscreen monitor in my '02 SS. I have already wired up the stock wiring harness to the new HU 16 pin adapter. There is another 8-pin adapter that has three wires: Ignition (yellow), ground (black), and parking sensor (green).
I was under the impression that the only thing I needed for a HU install was a wiring harness so I don't have to cut up my stock wiring.
My question: What do I do with this adapter? Is it optional for some cars?
I'm thinking of just tapping into the ignition and ground wires on the 16-pin harness and grounding the parking sensor wire to the chassis of the car. Is this correct?
Sorry for the noob questions, maybe I should have done this research beforehand.
Thanks in advance,
Matthew
But do you know what I'm supposed to do with the other wires?
Black should go to the black wire in the radio harness or to another good ground such as a dash mounting bolt.
Man, this thing is badass, I'll get pictures up real soon.
