Amp help, newbie
Old Dec 27, 2004 | 03:45 PM
XIII's Avatar
Default Amp help, newbie
I am new to stereo stuff and could really use some suggestions. I have 2 RF 4406 6.5" subs I need to power. I don't know anything about amps. What's the difference between 2 and 4 channels? Which amp would you guys suggest? I am not looking for anything crazy, just louder and a little more clear than stock. Thanks guys.
- Trey
Old Dec 27, 2004 | 06:28 PM
shouldaboughttheZ's Avatar
- Trey
Difference between 2 and 4 channel is 2 channel amps only has 2 channels to output the sound, usually used on subwoofers. 4 channel amps have 4 channels to output sound, usually on the mids and tweets of the system.
Old Dec 28, 2004 | 11:16 AM
XIII's Avatar
Thanks for the info.
How do you determine what wattage amplifier is needed for a given set of speakers? Is there a formula?
Old Dec 28, 2004 | 06:28 PM
The RMS wattage on the speaker is what the speaker can handle all the time. The Max wattage is what the speaker can handle at a peak.
Old Dec 31, 2004 | 07:30 PM
JarredWS6's Avatar
yeah what shouldaboughtthez said. look at the RMS of the speakers and find an amp with a similar RMS rating. Oh yeah and when your looking for an amp dont worry about peak output, you will rarely hit that. RMS is where its at.
Old Jan 2, 2005 | 02:42 AM
d james's Avatar
also know that a 1200 watt 200 dollar amp may not perform like a 200 watt 400 dollar amp. You get what you pay for, so don't get a crapy one. I'd personay go with a 5 channel, this way you can run all your surronding speakers off of the amp plus a sub for the rear. You could also put four speakers to two channels and the other two bridged to a sub, if your really on a budget, this would be with a 4 channel amp. 've done this for years without problems, just make sure the amp can handle the load.
