PAC OEM line adapter question
Old Jan 9, 2005 | 12:20 PM
golddot's Avatar
Default PAC OEM line adapter question
greetings, i have the navrone model for my 2001 Z w/monsoon, i plan on wiring it to my fact HU, i have no clue as to which wire mates up to what color on the HU, i did som esearching and found a wiring diagram a while back but it was for a TA and not a Z any suggestions, i am floundering btwn haviing it installed (150$) or just doing it myself, the spkrs and amp should be a no brainer. thanks, shawn
Old Jan 12, 2005 | 11:53 PM
golddot's Avatar
nobody?
Old Jan 13, 2005 | 12:08 AM
matts22's Avatar
I can't help you but I've got a quick question. Do you wire that in at the HU, or can you come out off the wires going into the amp from the HU at the amp in the rear of the car? In other words, do you have to rip out interior to put this in at the HU, or can it be put in by the amp by just removing the back passenger side panel? Or do I completely not understand this? Sorry, I don't know much about audio stuff. Thanks.
Old Jan 13, 2005 | 08:27 AM
shouldaboughttheZ's Avatar
Here is a diagram of the pin out on the amp. I hope it helps.
http://www.houston-f-body.org/tech/m.../AmpCamaro.htm
Old Jan 14, 2005 | 12:22 AM
golddot's Avatar
i was told you can do it both ways, i called navrone and got off the phone more confused that when i got there, it must have to hard wire in somehwere becasue it has RCA's and reg. wires.
thanks for above link.
