HELP! Headlight Problem
Old Jan 15, 2005 | 12:07 PM
Kounsy's Avatar
Default HELP! Headlight Problem
I have a 98 firebird and ive replaced the driver side headlight motor three times. The headlight will work for like a month or so then just go out. Does anyone have any idea why this happens.
Old Jan 15, 2005 | 12:53 PM
Rogue Leader's Avatar
may not be the headlight... I had the same problem turns out the wiring gets wet and gets screwed up... I had to rewire half the plug....
Old Jan 15, 2005 | 04:56 PM
Danny2tek's Avatar
Yea check the wiring connector this past weekend I installed the brass gears and when I looked inside the connector some of the pins had some corrosion.
