please help quick
Old Jan 29, 2005 | 02:34 PM
CamTom12's Avatar
Default ...Screwed it up...
i've got an autometer tach and it's got 4 wires coming out of the back
i need to double check what they are
white = tach signal
black = ground
red = accessory power
green = illumination
Is this all correct??
Thanks.
Old Jan 29, 2005 | 03:00 PM
LS1_SS's Avatar
from what ive seen I believe the red is the tacg power the white is the accessory power and the black is the ground, dunno about the green. What kind of tach is it? Try attaching a 9 volt to each and see what happens...
Old Jan 29, 2005 | 06:17 PM
CamTom12's Avatar
well, I just got back from hooking it up (I had a buddy post this for me because I was down at the shop and couldn't get near a computer). I assumed that the way I thought the wires were was how it worked... No dice.
Now my traction control doesn't work and the tach doesn't work at all. I guess I have to rearrange the connections a bit. At least I have the ground right...
Old Jan 29, 2005 | 10:09 PM
exstanger's Avatar
You have the green and white wires backwards. You may haev blown a fuse to the tach. Also it has to be (the tach) set up for a 4 cyl. engine
Here's a link to autometers directions http://hp.autometer.com/instruction_...tions/407j.pdf
hope this helps.
Old Jan 30, 2005 | 05:13 PM
CamTom12's Avatar
Made all the fixes and it works great! Thanks for the help!
