Removing Wires from Monsoon Head Unit, help?
Old Jan 29, 2005 | 03:22 PM
brianthomas7's Avatar
Default Removing Wires from Monsoon Head Unit, help?
I feel dumb because this is not working for me. I pulled the cd changer wire harness out but I can not remove the large one on the right side. I pulled pretty hard and pushed the little plastic tab on the bottom up but it wouldn't pull out. Are there any tips on this? Also how to I detach the black attena wire on the left side?
Old Jan 29, 2005 | 10:25 PM
VIP1's Avatar
Copy & Paste Moderator
Make sure you push in the locking pin/s of the plastic connecter as hard as you can and wiggle-tug until it comes out. The antenna connector just pulls out (at least mine did), but its hard.
Old Jan 30, 2005 | 09:44 AM
firebirdude's Avatar
Wiggle side to side. It is tough. Maybe need to use a small small flat scredriver. I think every antenna wire in every car ever made has been a little tough to get out. Pull straight out hard.
Old Jan 30, 2005 | 01:17 PM
The metal tip on the attena wire is supposed to come out with it correct?
Old Jan 30, 2005 | 02:25 PM
correct.
Old Jan 30, 2005 | 02:43 PM
VIP1's Avatar
Yeah, the metal tip is part of the antenna wire.
Old Jan 30, 2005 | 03:26 PM
Got it out. That was rediculous of me, way easy. I just wanted conformation before I went forcing stuff out. Thanks for the help, no more replies nec.
