Power Antenna Problem
Old Feb 2, 2005 | 11:59 AM
'99DeadulusWS6's Avatar
Default Power Antenna Problem
Alright, I know I'm gonna catch a little grief for driving in the winter, but that aside. Here's the issue. My power antenna is now making a terrible grinding sound when it's SUPPOSED to be moving either up or down. It's been stuck in one position before and I've 'persuaded' it down by hand before, and there's always been a little resistance. This time however, it slide in WAY too easily. I figure something's gotta be disconnected in there. Any ideas where and what to look for to rectify the situation would be greatly appreciated.
Old Feb 2, 2005 | 04:56 PM
VIP1's Avatar
Copy & Paste Moderator
Sounds like it might be broken. If it is, you can order a new one from GMPartsDirect for $70 + shipping.
PN: 10402859
GM LIST: $139.16
www.gmpartsdirect.com: $69.58
__________________
Old Feb 2, 2005 | 05:07 PM
02blackZ's Avatar
I had the same problem except mine made no noises at all, just stayed down. Checked the wiring, everything ok! Think the motor burned out! Had to reorder one today.
Old May 8, 2005 | 06:05 PM
mimic42100's Avatar
How can i "force" the antenna to drop down.
I dont care about it going up, as i never listen to the radio. always cd's.
Old May 8, 2005 | 08:37 PM
VIP1's Avatar
You can put a switch in the wire that powers it.
You can find a wiring diagrams here:
http://www.houston-f-body.org/tech/monsoon/index.htm
https://ls1tech.com/forums/showthrea...wiring+diagram
Old May 8, 2005 | 11:28 PM
ls1rocker's Avatar
if its stuck up, you can get to the actual unit via the spare tire well, and pull or cut the plastic gear strip that goes up into the antenna mast and pull that out
it ll go down after that
