Camaro subs vs. firebird subs
Old Feb 5, 2005 | 01:19 PM
01formula6's Avatar
Question Camaro subs vs. firebird subs
I've tried to find some info on whether or not the subs are interchangeable between the two cars and have had no luck. I'm trying to replace a blown sub in my formula and bought some replacement speakers that came out of a camaro. When I went to put them in I noticed that they had a different connection and were also 2 ohm instead of 4 ohm. So is it possible to still use these speakers or do I need to find some that came out of a pontiac?
Old Feb 5, 2005 | 01:54 PM
WhiteBird00's Avatar
Ungrounded Moderator
The Firebird speakers are dual voice coil, wired in parallel to produce a 2-ohm load. The Camaro speakers are single voice coil 2-ohm. They are interchangeable but you will have to modify the connection a bit. However, the Firebird speakers are a little higher quality and seem to be less prone to blowing out than the Camaro version so I would stick with the Firebird ones if you can get them at a reasonable price.
Old Feb 5, 2005 | 05:34 PM
BigBadWolf's Avatar
Keep iin mind that that the Firebird also has a 500 watt amp, double the Camaros so you might blow the Camaro speakers if you're not careful.
Old Feb 6, 2005 | 01:54 PM
01formula6's Avatar
Thanks alot, I did not know that. I guess I'll just sell the Camaro speakers I have and find another alternative.
