Tachometer installation
Old Feb 10, 2005 | 07:57 PM
RedWS601's Avatar
Default Tachometer installation
Does anyone know how to install a Tachometer? It is an APC don't really like it but was a gift. please help
Old Feb 11, 2005 | 03:52 PM
SSactionLs1's Avatar
you should have a
parking lights wire
tach wire
power
ground
tach is a white wire on the PCM
Parking lights you can grab right behind the switch, i THINK its brown...power you can get from the IGN harness, i dont remember if you want constant or ign power...constant is red and ign is pink...and ground it to any metal surface..
Old Feb 11, 2005 | 05:22 PM
ArcticZ28's Avatar
you want ignition power so tap into the pink one... no use in always powering a tach to read RPM's when the car is off.... unless you REALLY want to make sure the engine is off
Old Feb 11, 2005 | 05:27 PM
reason i wasnt sure is most tachs now have a memory recall...Dont remember if thats stored electronicly or not.
