couple questions on new setup
Two Audiobahn AW1251T Subwoofers
45 oz. Strontium Magnet
Power Handling: 400 watts RMS
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
MULT-CONNECT Lug Lock Terminals
Power by One Audiobahn A8002T Amp
Class D Power Amplifier
2 Ohm Stable
RCA (Low Level) and Speaker (High Level) Inputs
RCA Outputs
Mono Output
Input Sensitivity: 200mV ~ 8V
THD: <0.05%
Variable Low-Pass Filter: 40Hz ~ 120Hz
Variable Bass Boost Control @ 45Hz: 0 ~ 18dB
Air Induction Fan Cooled
Optional Accessories: ABR100T (Remote Mount Bass Boost Control ****)
ADM100T (Remote Mount Digital Volt Meter)
4-Way Protection Circuitry: Thermal, Short Circuit, Overload, DC Offset
200x2 @ 4 ohm stereo
400x2 @ 2 ohm stereo
800x1 @ 4 ohm mono
I will be putting these subs into a custom sealed box, that is about 1.7-1.8 cubic feet. Power supply isn't an issue. Does this amp match these subs pretty well? And the box a good size?
Thanks for any help,
-Kevin
Mark - Looks like it is a D, i thought it was a A/B.
