Newb needs help constructing his sub box
Old Feb 24, 2005 | 07:29 PM
AronZ28's Avatar
Default Newb needs help constructing his sub box
I need some advice on constructing a sub box that will hold my 12" Eclipse woofer in the driver's side rear trunk cavity.(like a stealth box).
How did you secure the box to where it won't budge when I drive crazy?
If anybody would send me some dimensions or a design for a sub box that you have built, that would be great too. I'll fudge the dimensions a little to get the exact volume correct for my application.
How did you seal your box to where it is air tight? I figure I'll use some silicone cauk on the joints.
Old Feb 25, 2005 | 07:56 AM
2000KCTA's Avatar
subthump.com check them out....might be better than making your own.
Old Feb 25, 2005 | 10:44 AM
AronZ28's Avatar
Yeah I'm sure they are a nice sub box, but I can go down to Home Depot and get some MDF, caulk, carpet, and spray adhesive for under $30.
Old Mar 14, 2005 | 02:25 AM
2MuchRiceMakesMeSick's Avatar
Build it out of card board first to get the measurements down.
99% of the boxes I build are fiberglass so they are air tight. You can put a layer of fiberglass in the inside of the box to seal it and give it strength. Fiberglass is not hard, just take patients.
Also I have never built a box for $30. One sheet of MDF is $25 plus tax.
Old Mar 14, 2005 | 11:24 AM
jimmy 2 Times's Avatar
what kind of eclipse? i dont know if you are going to get enough air space in the cubby hole for something like an eclipse, especially with MDF
Old Mar 14, 2005 | 09:20 PM
Richiec77's Avatar
I'm thinking the same thing. A guy here Snootch fit a 12" in there, but it was Fiberglass, bondo, Mdf. Not as cheap, and he got roughly 0.8 cu.Ft.
http://www.snootch420.freewebspace.com/photo4.html
Find his Website here
http://www.snootch420.freewebspace.com/index.html
And you can look him up under "Snootch" here, and PM him for some info and advice.
Old Mar 14, 2005 | 10:11 PM
Firehawk526's Avatar
...and for the serious competitor who wants a challenge (great info)
www.bcae1.com
Old Mar 15, 2005 | 12:21 AM
That doesnt look too bad. Could use some work on the filament but not bad at all
