Turn Signals?
Old Mar 21, 2005 | 12:05 PM
Brentb's Avatar
Default Turn Signals?
I have a 99 Camaro SS the turn signals will not work. However the hazard flashers work. When i click the blinker on nothing happens the arrow on the dash does not light up. Checked all fuses. Need help
Old Mar 21, 2005 | 07:13 PM
VIP1's Avatar
Copy & Paste Moderator
There are probably lights out somewhere or a bad electrical connection. Turn on the hazards and look for lights that are not flashing (or are behaving "oddly"). If all the ones that are supposed to flash actually flash, then replace the flasher. The Signals and Hazards use different flashers.
Also...
A search could have answered your question:
https://ls1tech.com/forums/showthrea...ghlight=signal
https://ls1tech.com/forums/showthrea...tronic+flasher
Old Mar 21, 2005 | 08:06 PM
Brentb's Avatar
Default Thanx
Ill try it tomorrow i had been wondering if there was two flashers. Is there two panels i have to go throught to get to it?
Old Mar 21, 2005 | 09:53 PM
ACW's Avatar
ACW
https://ls1tech.com/forums/showpost....92&postcount=5
Links to plenty of turn signal info, iirc at least one of them has photos.
Old Mar 21, 2005 | 10:29 PM
VIP1's Avatar
I haven't had to do it yet, but they are both hidden behind the shin panel under the steering wheel.
Old Mar 22, 2005 | 07:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
The turn signal flasher is clipped to the underside of the dash to the right of the opening when you remove the knee panel under the steering column.
