Monsoon sound system
Old Mar 23, 2005 | 10:59 PM
LS1BlackBird99's Avatar
Default Monsoon sound system
I just bought a new car tonight and the speaker right behind the driver's seat is completely blown. Other than that I am pleasantly suprised at how good the stock system sounds. Anybody know where to get a replacement for it?
Old Mar 23, 2005 | 11:12 PM
ncd1966's Avatar
Go to the Dealer Both of mine went out. I looked for months for some stock replacements and could not find any with the right ohms. so I went see the Dealer and man they sound a whole lot better than blown ones
Old Mar 24, 2005 | 12:43 AM
2MuchRiceMakesMeSick's Avatar
I would use this as chance to upgrade to some aftermarket speakers since the dealer is probably not going to let them go for cheap.
Infinity provides a good low cost solution.
Old Mar 24, 2005 | 11:28 AM
WhiteBird00's Avatar
Ungrounded Moderator
It's pretty hard to find aftermarket 2-ohm speakers and, although 4-ohm speakers can be used, it takes some planning to avoid having the replacements washed out by the remaining stock speakers (because the 4-ohm replacements will run at a significantly lower volume). Replacing all of the original speakers would solve that problem but will be quite a bit more expensive than buying a single stock replacement speaker.
Old Mar 24, 2005 | 02:28 PM
Your right. I understand that a 4ohm will have a greater resistance to electrons then a 2ohm resulting in a slight change in volume. The reason I told him to get infinity is because they are a low cost/low wattage solution that will sound ALOT better then stock
Old Mar 24, 2005 | 04:11 PM
BrandonSS's Avatar
FWIW.. never had experience with them first hand but, Sounstream coax are 3ohms and are 92dB for the 6.5" Tarantula model.
Old Mar 25, 2005 | 02:22 PM
http://www.soundstream.com/sub/produ...akers_tar.html
Look to be pretty good. I have yet to hear a set. They are mostly known for their SQ amps.
Old Mar 26, 2005 | 09:46 PM
Z-286speed's Avatar
Right behind the door is there subwoofer they put in, i am looking into replacements for that.
Old Mar 30, 2005 | 01:46 PM
Got a new speaker in the mail today. Now I have to go out there and figure out what all I need to take out to get it in there.
