12v Source
Old Apr 4, 2005 | 04:01 AM
zrated's Avatar
Default 12v Source
Where is a good 12v ignition souce under the hood im wiring up my nitrous system and window switch
Old Apr 5, 2005 | 12:53 AM
zrated's Avatar
t-t-t
Old Apr 5, 2005 | 11:56 AM
iamsickofitall's Avatar
i used the ignition output on the dash fuse panel for my switched power source when i hooked up my nitrous system...for the constant 12v power go to the battery or the alt. output under the hood on the driver's side...it's got a red cover on it...can't miss it...you'll get more responses in the nitrous forum...btw that is one huge fuel pump you have there for the mods you have
Old Apr 6, 2005 | 02:21 AM
zrated's Avatar
ya your telling me its a huge fuel pump, only good for the things to come. Cam,heads. Direct port 200 shot. full bolt ons, had to replace it the stock one was going bad so just went big. So under the dash I'll see the fuse panel and just tap into the ignition fuse. I was thinking about doing this under the hood but it seemed impossible to find the right wire at the fuse box. Thanks Chris
