Driver side window on '00 Camaro
Old Apr 4, 2005 | 09:29 AM
1FASTZ28's Avatar
Default Driver side window on '00 Camaro
My driver's side window will not work at all, I know the motors are bad on the f-bodies, and have also heard that the switches will sometimes go bad as well. I think it is my motor, but from what I have read on here most people are able to get their window to go down but not back up all the way with a shot motor, would you still suggest I change the motor or could it be my switch. And any other help as to what I should look for. Thanks
Old Apr 4, 2005 | 09:56 AM
shouldaboughttheZ's Avatar
You could always unhook the motor and hook up a voltmeter or test light at the plug to see if it is getting juice. If so, then it is the motor.
