Line Lock Wiring
Old Apr 25, 2005 | 12:39 PM
99FormulaWs6's Avatar
Default Line Lock Wiring
The car I bought has a line lock installed, yet the person before me, ripped part of the wiring out. The front wiring is there, however from the line lock to the cab is gone. Does anyone have the diagrams? or can anyone tell me what I need? Wires? Switches? Connectors?
Old Apr 25, 2005 | 09:03 PM
2FAST4U's Avatar
Simple Ground one wire power other wire with a push switch. Oh and always fuse power wire.
Old Apr 26, 2005 | 02:20 AM
Richiec77's Avatar
Yup. It's as simple as 2FAST4U explained.
Since you said the Prev. owner ripped the wiring out I would test it 1st before runnign the wiring inside and buying anything else.
You can test to see if the Line Lock still works by taking the wiring as it is and stripping the ends. Then use a 9.6v to 18v Drill battery. Just hook one end to + the other to -. It should make a Clicking Noise and you should feel the "Thunk" of the Selonoid Activating.
