Airbag code
Old Apr 26, 2005 | 02:08 PM
Savage Messiah's Avatar
Default Airbag code
I think this is the right section...
I was in an accident, and it caused my airbags to deploy. I was wondering a few things about this, since the damage isn't too bad and I'm fixing it up.
1) Where is the front airbag sensor? I can't find it (97 V6 Camaro).
2) I have new airbags to put in, but before I do it I was wondering about the airbag code. I'm assuming that if I just install my new ones they'll pop right out since the code is still there. If I remove the airbag fuse and disconnect the battery, will that reset it, or do I need to clear the code out of the computer?
3) Can I reset the airbag sensor, or is it a one time use type of thing?
Thanks in advance.
Old Apr 26, 2005 | 03:02 PM
Got this answer off of camarov6, just wanted to make 100% sure
Originally Posted by 98Camaro3.8
The Inflatable Restraint Sensing and Diagnostic Module is in the center column, next to the shifter. It uses an accelerometer to measure the force of an impact.
The service manual says that any time the airbag is deployed, you must change the SDM.
Old Apr 27, 2005 | 07:45 AM
WhiteBird00's Avatar
Ungrounded Moderator
Yes, the SDM is under the console behind the shifter (almost directly below the console cup holder) and yes, you need to replace it every time the airbag deploys.
Old Apr 27, 2005 | 10:40 AM
cool, thanks... I replace that (and the airbags of course) and I should be fine? in other words there won't be any codes stored in the computer or anything?
Old Apr 27, 2005 | 10:57 AM
Nope, no other codes or problems to worry about.
Old Apr 27, 2005 | 01:27 PM
sweet, thanks a bunch
