wiring gauge for stereo system
http://www.streetwires.com/Flash/powerwire.html
I would run 12ga from the amp to the sub.
as for the battery, cap...they all draw power from your alt. the alt is the heart of everything, if u do not have a alt to keep up with your system and prvide the right amount of amps, it does't matter how many batteries or caps u put it you will never be good. when u add these item u are just adding more strain on your alt.
Yes/No. They are like a Battery, but they work like an Under-Flow device: Kind of like the Vacumme Canistors, or the Oil Things that discharge during Cold Starts (I'm high on Percs and Spelling comes 2nd).
Which is worse: a Battery or a Capacitor??
They both Require Energy form the Alternator.
Anyways, The battery is worse. They will draw a charge roughl the Same as a capacitor, but they don't discharge as readilly as a Capicitor. So with just a Battery Change, all you did was put a Slighlty better Designed Battery in place with a better Charge/Discharge rate, BUT not as good as a Cap.
Since You follow the Cap as another Device to draw current away from an AMP you are A Memphis guy. I was/Am too. For SPL purposes or where large continuous Current is needed, the Cap will hurt. It does begin to fight for Recharge Current also. So it becomes a Sap on the Current, become Resistance, and causes a voltage Spike in the Negative.
Here is a good link to see what it look likes and a great Explaination.
http://www.rockfordfosgate.com/scrip...Z2U9MQ**&p_li=
You should be fine with 4 ga if you have a smaller AMP for the Mid's/high's. But you are probably going around 50w per ch. so I would upgrade to 2 4ga or 1 2ga. I have 4ga Flat Power Wire from Memphis. It was an Awesome wire for under Carpet installs. I need to check to see if it is still for sale.
A cap provides extra protection when his battery cant discharge fast enough. His amps will run cooler and theres is nothing wrong with that.
Don't forget the Main Wires to upgrade:
Alternator to Battery
Ground Term (Battery) to Chassis
I have just recently been turned on by memphis stuff and I love their products. I started building my system with SQ in mind rather than SPL. I`m not into competition. I added the memphis amp just here recently to replace those crappy sounding rockfords I have. So it was built off of what I had already installed. I am still in the tuning stage and still have a ways to go to get it sounding right for me. Although, it sounds pretty darn good now. It has come to my attention that my preamps from my headunit are only producing about 1.3 volts and I need about 3 to properly supply my amp, so I am in the process of trying to decide how I want to do that. I have thought about doubling up my power wire from the battery, but would have to dig back into the car to do so. Not looking forward to that again. I was unaware of the flat 4 gauge memphis has. I`ll have to see if my stereo guy has that or can get it cause it`s pretty tight in there with what I have now. Thanks for the info though
Ok. Now I see why you would imagine them as a Resitance, rather than what they have evolved into. All of todays Caps for this Purpose are Low-ESR or Ultra Low-ESR Capacitors.
So you were a Tech on a C-130. I'm airborne so I love those Rough Planes.
Never had to Hesitate to Jump out of one! Lol
Memphis is a good Brand. I like there Class D amps for Subs. The 3004 is a good Class AB amp, just not up to snuff with some of the top amps, but the Memphis Bell is a nice amp.
They do have to versions Now: 1 is basically a Shared Pwr sply, 1100D, and 3004 (75x4, 500x1 4 ohm, 120x4 2ohm, 800x1, 1100x1 1ohm) and the Little brother (50x4, 250x1) anyways it's the 2004 and the 500 in a common Chasis.
You have Probably seen the Wesite So I'll quit.
Glad to have you back in the Hobby.
