Order's on its way, installing this weekend!
But now it's all here and I'm debating skipping work tomorrow to install it all heh. I'm about to go see if I can gut my car right now.
Three questions:
1) The button I've drawn an arrow to seems to get stuck in the depressed (LPF) position. A few nudges/presses and it will pop back up. Obviously not intended, but does anybody think it's enough reason for concern and to send it back?
2) How do all these buttons and dials need to be set? I read the manual to see what they do, but I don't know where they should be set.
Gain obviously adjusts the gain, but is that just personal pref?
The range button effects the whether the freq dial changes from 50-500 or 500-5k.
Freq changes the freq based on the range button, but where does this need to be set?
HPF for the front and LPF for the rear, correct?
Filter just turns all those crossover effects on or off.
Front end defeat seems to bypass the crossover AND the gain, so if it was on I guess I'd be getting a "flat" signal or something (if i used that word right).
3) There's a little diagram for bridged on the side of the amp that looks about like this (already put the digitcal camera away, forgive my MS paint):
That means I run a wire from the L- to the - on the sub, and a wire from R+ to the + on the sub, and leave the L+ and R- unwired? Right?
http://www.auburn.edu/~goldema/amp.jpg
Three questions:
http://www.auburn.edu/~goldema/bridged.jpg
1) as long as it doesn't keep dropping into the depressed position on its own, i wouldn't worry about it. once installed and set properly, you should not have to touch those controls again.
2) "Gain" should be set to match the Pioneer head unit's output, which is 4v.
You've got it on the "Range" button.
The "Freq" **** needs to be set depending on what you are using the pair of channels for. For instance, if you are connecting your Polk speakers on the front channels, you would set the "Type" button to "HPF" (High Pass Filter), which will only allow frequencies above the selected "Freq" setting to be passed on to the speakers. I personally would set this to something between 80Hz - 100Hz.
For the sub on the rear channels, the "Type" **** should be set to "LPF" (Low Pass Filter), which will only allow frequencies below the selected "Freq" setting to be passed on to the sub. Again, I would set this somewhere between 80Hz - 100Hz.
This setup will cause all frequencies above 80 - 100Hz to go to the Polk speakers, and everything below 80 - 100Hz to go to the subwoofer.
If you don't want the amp's built-in crossover to be enabled (such as if you have an external crossover, or a crossover built in to your head unit), then set the "Filter" button to "Off". The Pioneer P80MP head unit does have a built-in crossover, but it is only selectable at 50Hz, 80Hz, or 125Hz, so I would use the amp's built-in filter, as it is infinitely adjustable between 50Hz - 5000Hz. Just don't use the filter on both the amp & head unit at the same time....unless you know exactly what you're doing, this will usually hurt sound quality.
As for the "Front End Bypass" button, I've never seen anything like that before, and I'm not sure why you would want to use it. Personally, I would just leave that off, set the gain to the right input voltage, and if desired, just turn the crossover filter to "Off" if you don't want to use the amp's crossover.
3) that's exactly how you would need to wire the sub to the amp in order to bridge channels 3 & 4....keep in mind that this is how to do it for this particular amp only, it may be different for another make/model of amp.
Everything 02Z28LS1 said is correct, great advice. If you want to create deeper bass to your sub, decrease the frequency for that channel(s) to 50Hz, then it will only get the really deep, low bass. If you want a little more punchy bass, set it like stated before, about 80-100Hz.
I prefer deep bass out of my subs, but the best advice is to start where 02Z28LS1 said, and then tweek the frequencies to what sounds best to YOUR ears (this is where a friend really comes in handy, otherwise you have to keep getting in and out of the car).
Happy Listening!
DO NOT USE BOTH HU and AMP CROSSOVERS AT THE SAME TIME. I don't care who is tuning, it always leads to problems.
I think you are going to have to use the Pioneers internal Crossover to control the Sub output level. I haven't messed with that model or any of the Latest models to know if it will do that or not. Mine you have to have the Sub crossover on to control the Level from the Radio.
You are just going to have to hook it up and see if you can control the Volume with the Sub Crossover OFF or ON.
If you can, I'd go with the Quarts Crossover.
For starts, 80Hz for the Polks HPF, and then do 80Hz LPF for the Sub and work from there. It's going to be a rough guess because they are ***** and not Clicked indents AFAIK. Guesstimation is about as good as it gets.
Make sure the input button is out. 4ch input (2 sets of RCA's going into the Amp Correct?)
You are correct on the Range, Filter HPF/LPF (HighPassFilter, LowPassFilter). Filter ON/OFF is just that.
The Front end defeat is meant for Large Systems or True "Compitition" systems where Line Divers are being used along with external Crossover Networks. It does bypass the Gains and the Crossover. It there for does not amplify the input signal or tailor the signal. The Amp just Amplifies without add system noise. Not need here. Leave it on.
This is the Online Specs. Go to the Bottom and Click on the Q-Line Amp Similator. Won't be what you have but can explain some of the Functions a little better.
http://www.mbquart.com/2003/en_US/pr...&model=RAA4200
Here are all the available setups in the manual:
If I'm not even going to be running rear speakers, would I need rear RCAs? I'm only going to have the polk components up front and the sub in the back. I'm disconnecting the stock back seat speakers and the stock hatch speakers, and leaving them disconnected.
I would use the 4-Channel setup and run one set from front output of deck to front input of amp for your polks, and the sub output from deck to rear input of amp for your sub. This way, you can still fade your sub, or boost it via the head unit. This basically allows you more "tuneability" of the system, why limit that? Make sense?
heh, how about like this?
:https://ls1tech.com/forums/showpost....6&postcount=15
anyway, yeah, that should work. and like it was mentioned, you don't have to use the Pioneer unit's crossover on the sub channel to control the level, you can always use the set of RCA outputs labeled "Rear" instead of "Sub" or "Non-Fading", and just use the front/rear fader to control the sub's output level. but yes, regardless, you will want to run a pair of RCA's for the fronts, and another pair for the sub. it just makes it so much more flexible of a system than running a single pair of RCA's.
and as for my suggestion of 80 - 100 Hz on the crossover points before, i take it back. i have pretty much the same setup, one set of components up front and a single 10" sub in the back, and so far i have had the best sound (at least, what sounds best to me) by setting the fronts at 60Hz high pass and the sub at 50Hz low pass. it dramatically pulls the soundstage up front (where it should be), and will do so even more when i replace my crippled 5 1/4" components with a brand new 6 1/2" or 6 3/4" component set that can handle a little more bass.
but again, that gives you a couple starting points, play with the crossover points to get the sound the way you like it....after all, you bought the system for yourself, who cares how other people think it sounds, right?
his amplifier wiring kit has a set of RCA's that has the remote turn-on wire built-in, so unless he pulls it off the RCA cable (may or may not be possible, depending on if it's ran down the middle, or one of the sides of the RCA cable shielding), that's not an option.
And I can seperate the remote lead I believe. The RCAs that came with my wiring kit have the lead in the middle, but the second RCA that I bought seperately has the lead on the outside so I should be able to seperate it without much effort.
As for the amp ground, it says to fasten it to the chassis using a non-adonized screw and star washer. Will any of the bolts in the hatch area work? There seem to be plenty of them, especially behind the carpet on the back wall where I'll be mounting my amp anyway. But are those non-adonized? I think they are black, meaning they might be painted... And there certainly aren't star washers, but what does that matter?
anyway, i connected the ground for my amp under the nut that attaches to that silver tube that the antenna on the passenger side rear sits in, behind the spare tire. if you remove the spare tire, you'll see what i'm talking about. it's a real shiny silver bar with two bends (curves) in it. of course, my amp wiring is only 8ga instead of 4ga, but with the proper termination connector on the end of the ground cable, you should still be able to use that spot. if not, just make sure that wherever you ground it has the paint scraped/sanded away so that the entire terminating connector makes contact with sheet metal.
as far as a star washer, it just helps grab hold of the connector on the end of the cable a little better, but if you have one of those closed-loop type connectors, it's a moot point.
Anyway, gotcha. In fact I noticed that silver tube earlier today when I was pokin around the hatch earlier today checkin out where I might run wires.
Thanks a ton guys. Hopefully my next post will be one to say I've got it up and running. Gimme a few days. =p
I played it all at "low volumes" for about 20 hours as was suggested in the sub's manual to break it in, and then cranked it up to set the gain. Following the amp manual on how to set the gain, it said to turn the gain all the way down, the head unit all the way up, and then slowly increase the gain until you hear distortion or the clipping LED begins to light up. That produced these results (tiny red markings where I set them):
As you can see I barely turned the gain up for the highs and the clipping LED came on. The clipping never came on for the sub, but I started worrying how much gain I should be putting to it since I thought I might tear it up or rattle the back of my car apart, so I just set the gain in the same place as I did for the highs. I pretty much set the crossovers at about 8:30 on a clock face, that should come out to be around 100hz between 50 and 500. I'm not sure how sensitive/accurate the frequency **** are though, so I'm tempted to turn off the amp's crossovers and use the head units since I can set a LPF and HPF at 50hz, 80hz, or 125hz with the touch of a button, and it indicates what it's set at so I know for sure.
I also might turn the gain up to about half way, and just not turn the head unit all the way up. Even though it's set now to where it won't distort if I turn it all the way up, I'd prefer to only have to adjust my volume in the 10-30 range instead of the 40-60 range.
Also, my highs are a tad bright at high volumes, so I might try and re-angle them or just fool with the EQ and turn down the treble a notch.
All in all, it's goin great. And as for the install, boy what an endeavor. Started late on the first day, only spent a couple of hours trying to get all the carpet up and the wires ran through the firewal and under the carpet. Day two consisted of about 4 hours in the morning of figured out how to put together the dash kit, what wires to hook to where, and how to fit the head unit in the dash heh. Then lunch, and four more hours of figuring out how to get the speakers in the doors lol. Hooked everything up and it ran fine, so day three I just spent a couple of hours finishing up. Mounted the tweets, crossovers, amp, and sub. Spent the rest of the day cleaning out the interior and washing the car, and discovering I can't polish my wheels up like I had planned. But that's another story for another time. =)
----------EDIT-----------
OH! And the absolute WORST and ironic thing happened. After becoming a self proclaimed master of car audio, my computer sound decided to stop working and I can't figure out why. =\ My Klipsch Promedia 5.1 Ultras produce nothing out of the 5 satellites, just bass out the sub. I hook up headphones and it sounds fine though, so it must be the speakers and not my soundcard. I've checked, double checked, and triple checked and I can't see anything I hooked up wrong. *shrug* *cry*
not a good idea...the volume numbers on the head unit don't matter in the slightest. if you start cranking the gain up, it will still be amplifying a lot more noise, even with the volume lower, than it would be if the gains were set correctly with the volume turned up higher. amplifying noise = reduced speaker life. and i definitely would not recommend turning up the gain if it results in the "clipping" light coming on.....
as for which crossover to use, you can probably get away with using the x-over in the h/u instead of the one on the amp. that's what i'm doing with my Kenwood h/u, i have mine set to 80 HP/80 LP....the cool thing about my h/u is that it has a lot more than just 3 x-over points, so i have a wider variety to choose from, and i adjust it depending on what type of music i'm listening to (which makes it handy to be at your fingertips). for rap or stuff that has a lot of bass/midbass, i tend to set it at 80 HP/80 LP, and for rock/metal, i usually set it at 60 HP/50 LP. for country music, i change the station!
heh, j/k, i don't listen to the radio anyway......i can't stand having to change the damn channel after listening to 1 - 2 songs, and there's not even really any good stations in B/CS anyway, so i just hook up my MP3 player that contains my complete CD collection and jam away to exactly what i want to hear....
